need help with brake conversion
New User
jus some quick questions. i am trying to do a brake conversion for my 94 civic cx using 98 gsr . basically i have the whole thing from suspension to brakes and all.(car was totaled) i was reading the threads and i dont know if some info here are right or wrong or jus different ways to do the swap, but i wanted to know what i needed to do it. would i need anything else to swap or can i jus use wat i have from the gsr? need to do asap...any help would be greatly appreciated
Re: need help with brake conversion
its all mechanical.. everything should just fit in place if you got the whole brake swap conversion as a complete with nothing cut etc... just try it out and I guaranteed you'll learn more by first hand experience and save money. It will work!
New User
thanks will try out and see . hopefully it wont be too bad. anything i should be aware of before starting swap?
o..and one more question about the abs..there was something about using a non abs master cylinder or is the gsr one fine and also the prop valve?
Specail Ed
02-25-2003 02:19 PM
Yellow Dragon
06-07-2001 08:15 PM
