3k+ cold idle
Old 03-20-2009, 08:30 PM
ShinyNewPenny's Avatar
Default 3k+ cold idle
1993 Civic Si, d16z6, no CELs. When it's any colder then about 40 degrees(F) outside my car idles at atleast 3000. It will slowly drop as the car warms up, usually within a couple mins it will be down to 1k and fully warmed up idle is about 500 or so. It's been doing this for a little over a year now and I've pretty much gotten used to it, but lately it's been annoying.
I've read a little online about the FITV and IACV, but I dunno where to start for a problem like this. Should I try cleaning the FITV? If so, how(lol)? What could the problem(s) be and how should I go about fixing them?
Old 03-20-2009, 08:50 PM
trustdestruction's Avatar
Default Re: 3k+ cold idle
It's suppose to do that. Well, maybe not 3000RPM though. I'd clean the FITV. There's a link to a how-to on it in the FAQ section.
Seems that your FITV is doing its job but not doing it properly.
Old 03-21-2009, 12:35 PM
I know that it's supposed to idle a little high when cold, but 3k is a bit much. I've seen it go up to about 3300 or so when it was about 0 degrees outside.
Old 03-21-2009, 12:38 PM
drave's Avatar
Mine does this too. when it's -40 celcius, it'll idle at about 3k, drop down to 2200 after about 5 minutes, then after about half hour later, it'll idle normally.
Old 03-21-2009, 01:32 PM
Former User's Avatar
Speculation: Contraction of the throttle body or IM in cold weather may be producing an intake air or vacuum leak that eventually closes up due to expansion when the engine is hot.
jdmgeezer
12-09-2007 11:23 PM
minner
10-08-2006 01:30 PM
tylerdurden
04-11-2003 05:53 PM
Quick Reply: 3k+ cold idle
