misfire and idle problem, please help
Old 03-19-2009, 03:16 PM
junior h.m's Avatar
Default misfire and idle problem, please help
okay my car is a 00 honda civic ex, stock motor,i/e. Thats all.
It first started with the check engine light, so i hooked up the scanner and the code was P0505 and P0301.From what i understans code P0505 is idle speed control system,i tried finding the problem but have found nothing.I replaced the throttle body and IACV already.And the code still comes on after driving it for a while.Also code P0301 says Cylinder 1 Misfire Detected. What can i do too get rid of this problem.
Last thing i want to hear is replace motor lol..
so any help will be appreciated.
thanks H-T
Old 03-19-2009, 03:26 PM
Russyo's Avatar
Default Re: misfire and idle problem, please help
have you checked the wire for cyl 1, or the coil pack. Doesnt that year have a coil pack for each cyl?
Start there.
Old 03-19-2009, 03:34 PM
pm for noodz
turboteg90's Avatar
Start there.
are you the russyo from di?
edit-you are,just saw the t1 sig,lol.
Old 03-19-2009, 03:38 PM
junior h.m's Avatar
yeah i should check that, no no individual coil pack, thats only on newer cars i believe.. it just has distributor and plug wires....
junior h.m's Avatar
also what about the P0505 code?
Old 03-19-2009, 03:42 PM
Sr420Det's Avatar
Check if its firing first. Start cheap, spark plugs and wires then move to the dizzy. Try cleaning out all the connectors to the iacv and tb sensor with electrical connector cleaner. Also check those connections at the ecu.
Old 03-19-2009, 03:46 PM
junior h.m's Avatar
just did all of the above mentioned...earlier today....checked just right now too make sure the plug wires are all in correctly,everything is fine. what i do notice is that the cam gear wich is a skunk2 looks like its wobbly...the timing belt shakes a bit..might be out of timing?
Old 03-19-2009, 03:47 PM
Russyo's Avatar
thats possible, also, trying swithcing number one and number plug wires, and see if the problem follows the wire.
And unplug the wire one by one while the car is running, and see if one doesnt make a difference.
Old 03-19-2009, 03:49 PM
junior h.m's Avatar
ill go do that right now, ill be back with updates..
Old 03-19-2009, 03:59 PM
junior h.m's Avatar
okay did what you did, same problem, but now its showing misfire on all cylinder's...
Old 03-19-2009, 04:44 PM
Sr420Det's Avatar
Duh, Is it running like complete crap, skipping every other revolution or just skipping every once and a while? Your misfire may be a symptom from the 505 but I doubt it, I think it just detected a brief interruption not a complete malfunction. Have you cleared the codes and checked it out?
Old 03-20-2009, 10:14 AM
junior h.m's Avatar
it doesnt skip, at all..it makes this freaking loud winding noise(kind of) untill it gets too about 4th 5th gear...
rupensane
10
04-02-2008 04:10 PM
ay_dawg
09-20-2006 01:56 PM
bags
09-13-2004 09:10 PM
TwistedSI
14
06-20-2004 04:24 AM
pulse_crx
12
10-24-2003 05:33 PM
Quick Reply: misfire and idle problem, please help
