CEL Code 22 D15B
CEL Code 22 D15B
I have a JDM D15B OBDII 3-stage VTEC motor (I know.. OBDI D15Bs are really hard to find now) in my EG hatch. I have a P28 ECU and obviously the OBD I O2 hooked up and I have no check engine lights. I have only the regular VTEC solenoid hooked up (because you can only plug one into the USDM harness). I am sure it is the regular one and not the vtec-e one because it has the green wire which is usually used to indicate regular vtec. Anyway, the motor is running fine and I am able to redline the car and engage vtec perfectly fine.. until 4th gear. When reaching 6000 RPMs in 4th gear the CEL light comes on (code 22) and I cannot rev any further. Since I am able to engage vtec in every other gear that means that my pressure switch is most likely working. I am not sure what the problem is and I don't know if getting a new vtec pressure switch will fix it. Yes, I have checked the oil level and it is perfect!
Any thoughts?
Any thoughts?
Re: CEL Code 22 D15B
I don't understand what you're telling me to do. Are you saying that even though I have one of the solenoids hooked up I really don't have vtec? Why would I bypass the pressure valve? Isn't that needed for vtec to engage properly with USDM ECUs..
check your connections i just had a problem like this and here is what i was instucted to do... ill post the thread
he instructed me on what to do... mine ended up being a loose wire... but heres how to go about it
g/l
here it is
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/csf-sensor-obdiia-2529435/
g/l
here it is
sorry but if you cant understand that i dontknow what to tell ya
see if you can try a friends pressure switch
its the one on the bottom side of the solenoid with two wires going to it
unscrew it... screw a friends in and see what that does for you
a new one is like 60
Yeah I was gonna try looking for a friend who has one to let me try. I was just asking here first because maybe someone knows that its not the pressure switch or something.
oh i had code 22 last night and today i went to the drawing board after the help from the guy in that thread... just before i was getting ready to switch the pressure switches i figured id tug on the wires since a friend and i recently wired them... turns out one of the wire ties didn't hold so that ended up being my problem
Yeah, I've already tried messing with the wires. I only get the code 22 light when I am going WOT on the highway and almost redlining 4th gear. So thats not quite often..
92sihbk
20
12-25-2007 08:21 PM
cioli
12
02-26-2006 08:31 AM
ViXoN Hatch94
11-28-2005 01:40 AM
b16ek4
06-20-2005 07:23 AM
