turn signals wont blink and no gauge in dash is working
I was putting on my new sidemarkers and decided to test the blinkers and it blink for a second then it stopped. I checked all my fuses and everyone of them are still good. I moved the car and notice my gauges were working either. Does anyone have any suggestions what might be the problem?
Re: turn signals wont blink and no gauge in dash is working
same thing happend to me today to i was driving and noticed none of my gauges were working.
95 hb. Also, the hazards will work though
Carefully double check fuses 15 and 24 under the dash. Are the slots in the fuse box where these fuses insert damaged? Note that Fuse 15 protects circuits for both the gauges and turn signals.
ok i checked my fuses again and they are all fine. But one thing observe is that the clock wont come on with the ignition switch is on. And now i realize everything that is connected to the ignition power switch (blinkers, gauges, and clock) arent working. By a chance do you guys know if all three of them are connected together to the ignition switch power or something? I'm thing maybe theres an open circuit in a connection that connects all of them to the ignition power.
ok i double checked the ignition switch today and it seems fine... any other suggestions where the problem may exist?? because i really can't figure it out
Remove dash fuse 15 and check it with a multimeter. There should be continuity between the two terminals.
The diagram below shows all the components that rely on fuse 15 for power. Do any of these components work?
By the way, the hazards get power through fuse 43 not fuse 15.
ok i checked the fuse and found it was broke... i replaced it and everything seems to be working except my turn signals. but my flashers work. should i check my flasher switch because i wouldnt think it would be the relay because the hazards are working
i believe its my combination switch... i tested the continuity and it seems like its getting nothing. I'm head to autozone right now and see if they sell them. Thanks RonJ@HT for your help. much appreciated
I think Danomatic93 recently made a thread on how to repair a combination switch. In addition, test the switch and wires before buying a new combination switch. I'll post the diagrams.
ok i got everything to start working again it was my combination switch. I just cleaned the terminals. But i do have a major problem now!! my fuel pump wont start when i put the key on the second position... did i blow a fuse for it?? im not sure what i did.
Do the dash lights turn ON when the key is turned to ON(II). If so, check whether hood fuse 31 or dash fuses 18 and 24 are blown. If the fuses are fine, then the main relay is likely bad. You can replace or resolder it.
jOnW89
33
02-20-2010 04:03 PM
1SickHb
10-26-2005 08:49 AM
TecHnOCal
16
01-27-2004 06:36 AM
