eg hatch horn doesnt work...HELP!!!
Old 07-09-2009, 03:34 PM
flipldls's Avatar
Default eg hatch horn doesnt work...HELP!!!
can anyone tell me how to get my horn working again...horn fuse good, but every time i press the horn button you hear a clicking noise under the dash where the the fuse box is. so is it a fuse/relay problem or i need a new horn?
Old 07-09-2009, 03:35 PM
ballisticej1's Avatar
Default Re: eg hatch horn doesnt work...HELP!!!
I had the same problem too, never bothered to check it out.
Old 07-09-2009, 03:36 PM
K20egcw's Avatar
is the horn plugged in? lol
Old 07-09-2009, 03:45 PM
flipldls's Avatar
yeah. it used to work awhile ago, then it simply stoped. it seems the clicking noise is coming from a relay under the dash.
Old 07-09-2009, 03:54 PM
flipldls's Avatar
pull the relay out from the fuse box under the dash still made a clicking noise....are they any hidden relays or fuses under the dash that i'm not aware of...lol
Old 07-09-2009, 03:56 PM
flipldls's Avatar
thinking about gettin a new horn, but want to make sure thats the reason of the clicking.
shogee's Avatar
use jumper wires and send power directly to the horn see if horn honks. if not switch relay with a good one. then use a test light and hook up one end to ground, disconnect connector from horn, have some one press horn button and probe into connector to look for B+. if no then repair wire. also check ground connection.
Old 07-09-2009, 03:59 PM
Mt3c's Avatar
i'm replacing the horn on an integra right now. car was recently in an accident and had the horn dented, which allows it to only do a click once, then no noise.
i'm replacing it with a horn from 08 accord, OEM part with connector for around $15 bucks.
you can always try a friends horn first before buying a new one.
jorge.deharo155
12-14-2015 11:01 AM
hspoon
03-11-2009 02:31 PM
frizzo
11
07-22-2007 10:02 PM
Redemption
06-24-2007 03:18 PM
bgmat58
01-05-2005 08:44 PM
Quick Reply: eg hatch horn doesnt work...HELP!!!
