d15 mini me swap
d15 mini me swap
Ok. before I get flamed for not knowing I'll tell you I dont know.
I'm about to embark on a mini me swap journey. I have read the swap tut here in the FAQ section about a dozen times so dont refer me to that.
I need to know EXACTLY, EVERY PART I will need for this swap. I know I need the Cylinder Head, Distributor cap and rotor, I'm changing the intake manifold, timing belt water pump, valve cover, spark plugs, spark plug wires. I'm also replacing the head gaskets. do I need fuel injectors? The tut says most of the above and etc. I want to know whats in the etc part.
Thanks guys and gals
Re: d15 mini me swap
ok. simply for my own clarification. what I have listed up there including fuel injectors, vtec solenoid, the p28 ecu and pulling the oil jet is all I will need?
What will be necessary to wire the vtec?
sony224422
09-25-2015 10:50 AM
freddysEF
01-28-2007 12:15 AM
