Need Help: D16Y8- Water leak between head & intake manifold
I am finally done restoring and installing the rebuilt stock engine into my 2000 civic ex. When I fill the coolant, water leaks between the cylinder head and intake manifold. There is only one water bypass through the head to intake manifold.
I need help finding a solution for a solid permanent fix? I appreciate your help in advance!
Mike
Mike
Re: Need Help: D16Y8- Water leak between head & intake manifold
Mike
Mike
Intake mani gasket. Either it is not to spec on TQ. Or you did not clean the head or IM when you put the new gasket on
the head isnt even, and i have a brand new oem honda gasket on there. i dunno what to do next
it looks like the head is sanded on the IM side. I dont want to try to sand it because it may not be even as it is already done by previous owner. What do i do?
civicguy167
12-12-2012 09:11 PM
ivan93egreppin210
08-06-2010 07:52 PM
