very rough and low idle, dies after gas is applied
92 civic
B16a
i just got it running lastnight and this morning i replaced/fixed everything the CEL was on for
there is no CEL anymore and when i start it the idle is very rough and when i give it any gas it dies or starts to bog and tries to die
i figured it was either timing or the TPS so i adjusted the distributor and that didnt do anything.. i adjusted the TPS to .45v at closed throttle and 4.45v at WOT and the car wont start when i adjust it to .60v it starts but runs like crap
the coolant is all bled out
is there anything else i can check or adjust or do to try to get it running correct?
please help me
B16a
please help me
Re: very rough and low idle, dies after gas is applied
Pull the valve cover and make sure your crank and cam pulleys line up correctly. one tooth off will do what you're describing
Yeah check your timing belt n make sure it's not off.
Your TPS looks good voltage wise, unless there is something wrong with the potentiometer inside, the only way you can really check it is with an O-scope and looks for dead spots on the resistor.
Check your spark and fuel as well make sure things are good there and your not getting any type of a misfire, again an ignition scope would help lol
let us know what happens with it!!
well im pretty sure i narrowed it down to the MAP i have yet to check it cause i just printed the flow chart out for it today at school..
I had the same problem before. Ended up being the fuel pump after i checked everything else.
well i replaced the fuel pump.. my fuel pressure and volume are good..
still dont know what it is.. leaning towards the EIAC? maybe? but that wont cause a rich condition wich im getting.. along with the rough low idle.. wich leads me to the MAP.. any input would be great thanks..
oh no MIL either
oh no MIL either
turbo*s2k
06-06-2005 07:51 AM
Civiclx
04-11-2004 06:15 PM
