Em1 block code, not original ?
i have in my possesion a very stock 99 Si, (airbox,stock exhaust). upon inspecting i noticed the block code reads.
B16
serial number
Shouldnt this read b16a2????
i can only assume the short block has been changed???
B16
serial number
Re: Em1 block code, not original ?
usdm says b16a2, jdm says b16a, not sure what it means if it just says b16 with no a. mine from hmotors says b16a, then where the 2 would be there is a very faint HMO stamp.
if the serial number starts with a 5, it is an SiRII motor, if it starts with a 1 it is an SiR motor.
Sorry fellas i made a mistake, heres a picture, im just trying to find out if its the original block that came with the car or if the block has been replaced
Is it possible its just the older block with 99 si head on it?? if thats even possible?
What sensors should be different?
well its pretty much the same motor that the 99-00 si's came with, its just not usdm. its probly a jdm motor. and over seas they have been made alots yrs!! not quite sure what all cars had them tho
yes it is possible to put a b16 head on it as its the same motor.
