Speedo Jumping all over the place
Old 07-08-2009, 07:21 PM
The Lobster's Avatar
Default Speedo Jumping all over the place
So my speedo tonight just decided to take a crap everytime i floor it. THen afterwards it just jumps around eveyr so often or just goes back to zero. I could be driving then itll jump up and down and sometimes zero.
vss going bad? wiring somewhere?
Old 07-08-2009, 07:46 PM
Former User's Avatar
Default Re: Speedo Jumping all over the place
What year?
Old 07-08-2009, 07:48 PM
97 civic
youdontneed2cams's Avatar
Check the fuse for the cluster, mine did this quite often for some reason, it was always that fuse
Old 07-08-2009, 07:50 PM
Is fuse 15 blown? If so, click here.
Old 07-08-2009, 08:09 PM
just checked fuse 15 not blown. but good to know thanks for that recall!
vtechjunkie's Avatar
Does the motor stutter with it? If so, more than likely it is the distributor. The ignitor module goes out in them and they go all over the place. If not try the fuses. Or get a buddies dizzy to cross-reference.
Old 07-08-2009, 08:15 PM
Is the CEL ON? Might be a bad speedo or faulty VSS connector. Does the odometer also stop working?
Old 07-08-2009, 08:38 PM
sp00ledbseries's Avatar
vss
Old 07-08-2009, 08:44 PM
rpms are fine, car doestn stutter.
i didnt check the odometer but will do tomorrow.
no cels either.
Old 07-08-2009, 08:58 PM
shogee's Avatar
its probably the connector to the vehicle speed sensor. unplug it and clean out the connectors. it can get pretty corroded in there. mine did same thing, cleaned it, now it works good. vss is located on rear of tranny. plug goes in close to where the cv shafts come out of the tranny.
Old 07-08-2009, 09:04 PM
^that actually makes sense...when i did a swap that was a code i got but it went away when i tried to fix it. Ill pull it and clean it tomorrow.
parisz47
04-11-2017 05:02 AM
94eh2
02-02-2007 01:40 PM
STN_Pat
07-22-2006 05:46 PM
tpelley
11-17-2004 08:57 AM
smokinsi
10
09-01-2004 08:43 AM
Quick Reply: Speedo Jumping all over the place
