why does my car sag to the left
I got an eg coupe and ever since I bought the car it seems to lean to the left, especially in the rear. Now I've been researchin and most people r sayin its the springs yet some people r sayin struts. Now keep in mind I also have an oem setup. Another thing is I was thinkin about is gettin coilovers to fix the problem, although my back tires r prollly about 4 degrees off in camber. So my question is if I lower the car about 1.5"-2" on stock struts will I need a camber kit or just get it aligned?
Re: why does my car sag to the left
From what I've heard, on a stock setup you don't have to adjust camber if you're dropping 1.5-2".
Btw, I would go either with a coilover set or special shocks/spring setup because the stock shock can't handle a lowering spring.
it could sag to left because of the more weight on the left side due to the engine. but alot of cars have this problem. 1.5-2 you most likely will need a camber kit.
my car sags to the left with OEM suspension. other car is excellent because its got tokio struts + springs
yeah i was thinkin about gettin some $50 ebay specials but after reading ppls reviews they dont seem too good... i just dont have the money to drop on brand name **** right now, considering im a full time college student. looks like im just gonna be sittin on stock suspension for a while now
you need to check a couple of things. you can see if your springs over time have sagged under the weight. you can also have a piece of suspension that could be tweeked alittle bit. or it could be that your camber could be completely off on one side which will mildly tilt your car that direction. it could also be struts worn out. if worse comes to worse the frame could be possibly bent and covered up
The reason it's sagging is because it's got thousands of miles put on it by someone driving it sitting on the left side of the car. That's it. If you want to fix it get new springs. If you want to be able to adjust it, get coilovers. For the alignment, it will only be a toe set, camber and caster aren't factory adjustable. Typically caster doesn't need to be messed with. But for the camber, personally I like the adjustable ball joint for the front, and an adjustable rear upper control arm for the rear. I used the adj BJ on mine up front, and cheaped out and used some shims between the control arm and body in the rear. That will get you back into spec, and not make your car look retarded driving down the road with the wheels leaning in.
D16SohcVtec
04-01-2009 06:18 PM
