SI rear disc fit 97 civic hatchback? please help!!
I bought complete rear disc brakes from an SI owner parting out. arms brake lines pretty much complete. What do i need to put them on my 97 civic hatchback. Please help new to this.
Re: SI rear disc fit 97 civic hatchback? please help!!
Need E brake cables and 40/40 Proportioning Valve. First disconnect the brake lines and then e brake cables. You might need to lower the exhaust and remove the heat shield. Unbolt the rear trailing arms from the chassis and the rear lower and upper control arms from where it meets the trailing arms and also the toe arm. If the setup you bought came with trailing arms already attached then just replace the trailing arm you just removed. if not then you will need to unbolt the hubs from the trailing arms. I believe it is a 27mm and a T50 sockets. Not sure dont remember. better to double check. Bolt the new one back on. Install the ebrake cables, bleed the brakes and get a rear toe allignment. pretty simple once you take it apart.
EF9_TryMe
11-28-2009 05:21 PM
mingbling96
05-06-2006 09:55 PM
NikoZai
07-10-2002 02:50 PM
