Cam Seal Leak -- Aftermarket vs. OEM?
Old 11-01-2009, 08:43 AM
nonvtec92's Avatar
Default Cam Seal Leak -- Aftermarket vs. OEM?
Hey everyone. My Del Sol b16a3 looks to have a leaking cam seal. Is it refered to as a "cam cap seal"? I searched and can't find much... maybe i'm calling it something different?
The only solid thing I could find was an Integra DIY cam cap seal replacement. In the DIY it mentioned, that the honda units are pretty garbage, plastic and lacking an O-ring. That it's a common problem. Is this true? The author also mentioned buying an aftermarket unit, which was aluminum instead of plastic and had 2 O-rings on it. What would be the best way to go?
Thanks everyone.
If I should infact buy an aftermarket cam seal, does anyone know of a manufacturer to look for?
Old 11-01-2009, 08:46 AM
nonvtec92's Avatar
Default Re: Cam Seal Leak -- Aftermarket vs. OEM?
Oh, and to clarify... this is on the left side of the motor. By the vtec solenoid.
Old 11-01-2009, 08:50 AM
ricky ek4's Avatar
get yourself a "skunk2" camseal,i went for "password jdm" one after my engine
developed leak in same place.
its totally dry now.
Old 11-01-2009, 09:33 AM
John M's Avatar
I have never had a problem with a oem cam seal.
i infact do have a golden eagle one on my gsr swap and it shows no signs of leaking
Old 11-01-2009, 11:19 AM
B16aEk4drbeater's Avatar
oem ones are indeed plastic and junk, well, not junk but everyone of them start leaking at around 90-100k. the aftermarket ones look very nice and I guess IMO metal is better than plastic. just make sure you hondabond it before putting your new one on. Its 10-30bucks for an aftermarket one depending on brand.
Old 11-01-2009, 11:32 AM
rudebwoy's Avatar
just replace the orings everytime you remove it. running STR for years.
Old 11-01-2009, 12:23 PM
93egSLEEPER's Avatar
i have never had a problem with OEM. just run a bead of silicone over the top of it and in the head part where it seals and your fine.
Old 11-01-2009, 01:10 PM
wordsofvenom's Avatar
i have a golden eagle triple o ring b series cam seal, unopened for sale 20bucks.
thats ten bucks cheaper than what i paid. Cant go wrong.
http://www.hondamarketplace.com/show....php?t=2665935
Old 11-01-2009, 01:28 PM
thumper64's Avatar
It's a piece of aluminum with O-rings, Blox or even some no-name eBay one would probably be fine.
SLOENUF
03-12-2011 06:06 AM
DC-2guy
05-05-2009 06:36 PM
Walterronny
04-16-2006 05:16 PM
MattyP
12-31-2004 09:41 AM
Twigster311
05-22-2003 06:43 AM
Quick Reply: Cam Seal Leak -- Aftermarket vs. OEM?
