Snapped valve cover stud
I went to pick up a d16y7 today, seller said it's great condition etc. Turns out it has 2 snapped valve cover bolts. There's no space at all to grip it, it snapped .1cm from the surface. Any way I can get it out?
Re: Snapped valve cover stud
ok would lowes have that bolt extractor? and what size should I get? If it works I wont have to buy another head like i planned
What Ron said is the best way to remove the valve cover bolts. If the threads are in good shape, it should be easy to remove once you used a dremel tool to make a groove similiar to a flat head screw. The easy out tool requires you to drill a hole perfectly centered on the bolt without disturbing the threads on the head. I had a 93 Civic with a busted valve cover bolt and it only took a few minutes to remove it with a dremel tool.
The bolt broke below the head surface. I can't notch it without notching the head.
Bought one from lowes, we'll see how it works
00ekcoupe
37
09-05-2005 06:15 PM
