RPM Drop..h22a..ek
RPM Drop..h22a..ek
1.I have a h22a swap and i recently noticed that when i turn on my hids static comes on the radio and my rpm's drop low like a big noticeable drop.
I have upgraded the grounds with 4g wires.(Valve Cover and Tranny) I've also done something for the hell of it which was ground the Throttle Body.
Could it be one of the grounds are bad that is causing the problem..
2. I also didnt have the vacuum plugged in with the hose(p.o didnt connect them)..I now went and got a little hose to plug it up together with the Manifold and Vacuum.
3.Since this is my first h22a,i need to change the tranny fluid..where do i drain/add fluid and how much do i need..I was thinking of adding Redline Tranny Fluid.
yess im a noob and search sucks
srv3fender
06-15-2004 08:04 AM
92 in the works
12-03-2002 01:47 PM
