HELP!!!NO FIRE NO FUEL
Old 11-03-2009, 11:27 AM
turbo93daa's Avatar
Default HELP!!!NO FIRE NO FUEL
Stock 95 civic ex, Parked it for 2 weeks..went to start it and nothing..fuel pump is not priming and i'm not getting any fire.The fuel pump is good, Replaced the main relay and tried another computer...any ideas anyone??
Old 11-03-2009, 11:29 AM
turbo93daa's Avatar
Default Re: HELP!!!NO FIRE NO FUEL
also replaced coil and ingnition module in the dizz
Old 11-03-2009, 11:47 AM
Former User's Avatar
I assume the starter is cranking the engine fine. Check the ground wire on the thermostat housing. It may be loose or corroded.
Also check whether fuses 31 (hood), 24 (dash), or 18 (dash) is blown.
Old 11-03-2009, 12:04 PM
turbo93daa's Avatar
which fuse is 31 under the hood..also fuses 24 and 18 are good but have no curent going to them when the key is on
Old 11-03-2009, 12:11 PM
Regarding no power to fuses 18 and 24, if 50A fuse 39 under the hood is fine, then the ignition switch may be bad.
Old 11-03-2009, 12:14 PM
Unceasing Measure
Archidictus's Avatar
I know it's obvious, but have you checked the battery? It may just need a jump.
Old 11-03-2009, 12:18 PM
turbo93daa's Avatar
lol yeah the battery is the first thing i checked..i'm thinking the ignition switch may be bad..i thought i'd get on here and get some input..wanted to make sure i wasnt getting ahead of myself forgeting to check somthing obvious
Old 11-03-2009, 12:19 PM
Well, the solution is sometimes the obvious, especially considering that the OP did not mention whether the starter cranks the engine.
Old 11-03-2009, 12:21 PM
turbo93daa's Avatar
yeah engine turnes over..sorry, also the battery light on my clusted does NOT come on when you turn the key on
Old 11-03-2009, 12:25 PM
Here's how to test the switch:
Old 11-03-2009, 01:32 PM
turbo93daa's Avatar
holy moly...the ignition switch is goooooooooooood!you think anything in my distributer could have somthing to do with it?
Old 11-03-2009, 01:42 PM
A bad distributor would not prevent the fuel pump from priming.
Check whether the Blk/Yel wire running from the IG1 terminal of the ignition switch to the under-dash fuse box has an open.
Old 11-03-2009, 03:35 PM
chris42192's Avatar
When you turn on your car, does your engine light stay on n dont turn off? cuz if so, then my solution was my main relay n ecu had to be replaced!
Old 11-04-2009, 06:39 AM
turbo93daa's Avatar
i'v been tracing wires all morning and nothing has turned up burnt or broken yet...i was messin with the relay again and the only wire thats hot at the relay is the yellow and white wire..i can jump that to the yellow and black wire at the relay and make the pump prime..and my battery light comes back on like its supposed to when i do that
Old 11-04-2009, 07:20 AM
chris42192's Avatar
When you put your key in ON is the engine light on and never turns off?
Old 11-04-2009, 07:25 AM
turbo93daa's Avatar
yeah it just stayes on...but my batt. light doesnt come on at all
Old 11-04-2009, 07:49 AM
jiggacivic's Avatar
check the ground strap on the coolant pipe/fan switch pipe.
Old 11-04-2009, 08:18 AM
chris42192's Avatar
k when my engine light never turned off, my solution was replacing all my fuel pumps and my battery and ecu and main relay...ALL BRAND NEW!
Old 11-04-2009, 11:55 AM
turbo93daa's Avatar
all that stuff is good...for some reason i'm not getting power to my relay..well i'm getting power to the yellow and white wire only..nothing else, i'v tried another computer,relay, and batt.
2ndthtsurplace
48
09-02-2011 12:45 PM
articsilber323
09-18-2009 10:07 PM
upallnite
12-27-2008 06:59 PM
hondarichard
04-08-2005 06:07 PM
94SiHatch
11-09-2004 08:04 AM
Quick Reply: HELP!!!NO FIRE NO FUEL
