DIY: Fix squeaky clutch - Honda-Tech - Honda Forum Discussion
Old 10-31-2009, 03:04 PM   #1
Default DIY: Fix squeaky clutch
I am making this DIY thread because I think this is a common problem.
When I pressed the clutch pedal down on my 97 Civic DX, I noticed an annoying squeak noise. I quickly figured out that the noise was NOT coming from the clutch pedal but rather from the slave cylinder in the engine bay. To be precise, the squeak was produced when the small rounded end of the slave cylinder (colored red in diagram) pressed against the corresponding cup indentation on the clutch fork (colored green in diagram). Over time, the grease that lubricated these contact points was lost, leading to a metal-on-metal squeak noise.
The fix was to (1) unbolt the slave cylinder by removing the two bolts that secure it to the clutch housing, (2) remove the rubber boot cover from the slave cylinder, (3) place a copious amount of hi-temp grease on the red and green areas, and (4) reinstall everything in reverse order.
NOTE: This procedure does NOT require detachment of the clutch fluid line from the slave cylinder.
The grease that I used was Coastal Uniplex Hi-Temp Grease from AutoZone, though other hi-temp greases would likely also be fine.
Enjoy the absence of a squeaking noise when you press down on the clutch pedal!
Former User is offline   Reply With Quote
Old 10-31-2009, 03:08 PM   #2
joelmatt89's Avatar
Default Re: DIY: Fix squeaky clutch
hmm ill keep that in mind if i ever get squeaking in mine, my jeep squeaks but i don't think thats the problem. I adjusted my clutch yesterday it's so much nicer now. I also went to adjust the break and found that the bolt holding the pedal arm to the booster rod was gone...that could have been bad
joelmatt89 is offline   Reply With Quote
Old 11-01-2009, 06:18 PM   #3
Laz's EP's Avatar
Good wirte up
Laz's EP is offline   Reply With Quote
Old 11-01-2009, 06:25 PM   #4
96_cvc_b16's Avatar
im gona try it on my buddy's car. hes **** squeaks every time u press the clutch too. hope it works
96_cvc_b16 is offline   Reply With Quote
Old 11-01-2009, 06:38 PM   #5
Linked's Avatar
wrap tape around the ball on the slave cylinder is another way to do it
something strong like duct tape
Linked is offline   Reply With Quote
Old 01-17-2011, 07:16 AM   #6
SHG_Claudio's Avatar
Mine squeaks a lot too, funny thing is my slave seals are bad and I'm going to replace it anyways. Good to know that this is where its coming from, thanks Ron.
SHG_Claudio is offline   Reply With Quote
Old 01-17-2011, 07:21 AM   #7
93egSLEEPER's Avatar
Good write up :thumb up: I have also used silicon based lube in the past to solve this issue. Helps to seal and keep the seals soft as well.
93egSLEEPER is offline   Reply With Quote
Old 01-18-2011, 05:09 AM   #8
The Grumpiest
grumblemarc's Avatar
You should link this in your sig.
grumblemarc is offline   Reply With Quote
Old 01-18-2011, 08:15 AM   #9
Thanks Ron, it seems like ur the man for each and every single civic job, thumbs up dawg
lxdriver is offline   Reply With Quote
Old 01-18-2011, 08:21 AM   #10
foo fighters's Avatar
YESSS IT WORKS!! NO MORE CREAKING SOUND! thanks out loud!
foo fighters is offline   Reply With Quote
Old 01-18-2011, 08:28 AM   #11
chrisdavis6's Avatar
My competition Stg1 on my gs-r squeaks when it grabs but I think that's different.
Kinda like sneakers on a newly finished gym floor. I kinda like it
chrisdavis6 is offline   Reply With Quote
Old 01-18-2011, 09:18 AM   #12
I was gonna do this DIY on my civic rightnow but when I went into the engine bay, I didn't see the clutch slave or maybe I missed it, I got a stock d16y7, can anyone tell me where the part is or if it looks different from the above pic so I can grease it up and stop that noisy squeaky noise
Old 01-18-2011, 09:30 AM   #13
The Grumpiest
It's right up front. You can't miss it. Is your car an automatic?
Old 01-18-2011, 10:17 AM   #14
Old 01-18-2011, 10:27 AM   #15
I don't want to thread jack, but while on the subject of clutch slave cylinders, has anyone had experience with the Exedy brand cylinders? Or is OEM the way to go? I know somewhere someone said not to use aftermarket here.
NotAJDMFanBoy is offline   Reply With Quote
Old 01-18-2011, 10:55 AM   #16
The Grumpiest
Quote:
You don't want to jack it but you did any way? Start your own thread.
Old 01-18-2011, 11:47 AM   #17
Thanks for the write up....mine is squeaking too but i'm just lazy to find out the problem towards this.
lovelove is offline   Reply With Quote
Old 01-18-2011, 12:43 PM   #18
sde780's Avatar
Thanks! My prelude's is squeaking...I'll try this
sde780 is offline   Reply With Quote
Old 01-18-2011, 11:05 PM   #19
Quote:
Nah its manual tranny
Quote:
Originally Posted by HBKFanatic View Post
What should I do with it? Bleed it like the breaks, and if so, what kind of fluid to put back in it?
I just checked out the engine bay and finally saw the clutch bleeder valve, but when I push on the clutch, it seems to me that the squeaky sound is coming from the clutch pedal itself or somewhere very close around that area. Any ideas to where it might actually be coming from?
Old 01-19-2011, 05:34 AM   #20
The Grumpiest
There were directions given in the first post.
Old 01-19-2011, 06:00 AM   #21
Banner's Avatar
Banner is offline   Reply With Quote
Old 01-19-2011, 08:43 AM   #22
amej8's Avatar
My clutch used to "creak", not "squeak". I don't know how or why, but it stopped a long time ago. I'll definitely keep this in mind next time I start hearing it again.
Thanks Ron!
amej8 is offline   Reply With Quote
Old 01-19-2011, 11:43 AM   #23
yeah but wont like some kind of clutch fluid come out when I disconnect the clutch line from the cilinder like the Ron's first post and if so, what kind do I put back in it?
Old 01-19-2011, 11:55 AM   #24
The Grumpiest
Where did it say to disconnect the line?
Maybe you can't see the color red.
Old 01-19-2011, 01:44 PM   #25
This dude is mad dumb lol!!!
DC2R clutch feels weird H.N.F Tech / Misc 5 10-01-2016 09:29 AM
DC2R clutch feels weird H.N.F Transmission & Drivetrain 1 10-01-2016 06:20 AM
Squeaky clutch - Honda Civic 95 1.5l LSi EG4 BeanieHat Honda Civic / Del Sol (1992 - 2000) 7 09-24-2016 09:40 AM
Is it possible to grease clutch fork pivot without removing transimssion? Sprockets Tech / Misc 16 05-21-2016 06:11 PM
Rear brakes squeak upon disengage Steisler Honda Civic (2001 - 2005) 4 02-09-2016 01:33 AM
Tags
2000, 2002, accord, arm, civic, clutch, cylinder, diy, fork, honda, hondatech, lubricate, noise, prelude, replacement, slave, squaky, squeak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
