93 CIVIC EX runs lousy when warm....
this just started recently... The car runs fine when cold for about 10-15 minutes, and then when at normal operating temperature, it starts getting sluggish, stuttering, etc... At lights it sounds lke its missing and you can see the headlights dim a bt while the tach goes down then jumps a bit.
I've read similar issues but not one really told what was causing it. Has anybody experienced this? Car is well maintained, not beat.
New wires and plugs about 1 year ago (still not ruling this out). new cap and roto about 3 years ago... I still want to take a peek at them again. o2 was replaced about 3 years ago also but can still be that I suppose.
No white smoke from exhaust (would prob eliminate head gasket) and lots of exhaust coming out of pipe (would prob eliminate clogged cat)
Any suggestions?
Any suggestions?
Re: 93 CIVIC EX runs lousy when warm....
No, not that I noticed.... Everything runs fine until the engine is warmed (10-15 minutes after driving). I believe the lights dim because the rpm drop so low when the car starts acting up.
Mine hasnlt stalled (yet) but it sure comes close at times.... I may change the o2 today to a spare one I have and see what happens.
Does anybody know if its possible to have no CEL on OBDI with a bad O2?
Yes, an O2 sensor can be bad without a CEL. Unplug the O2 sensor to see if the problem goes away. If so, the O2 sensor is likely bad.
ok... a little update.... I changed the o2 back to the original oem Honda o2... the car ran somewhat better but eventually started the same stuff (but it seemed not as bad)....
I started lookeing at different things under the hood... took off thr dist cap and there was a pile of rustyl colored dirt or soot in there. Cleaned it out with a chemical and put it back on. tried to start the car, and it did a backfire type sound. I dont think I let the cleaner dry as long as I should have and I took the cap back off and notices the coil post was loose and it broke right off when I touched it..
Now, is it hard to change that or should I just buy a whole new distributor since mine is original (1993 ex)??
The red dust is a clear sign that the distributor bearing is shot. Replacing the distributor is straightforward -- remove three bolts, unplug connector and plug wires. You should check the ignition timing when done.
Thanks for the input Ron... so, does my original issue describe that the distributor may have been going? Ran ok when cool (slight miss here and there) but when warm, run like crap and bog down a bit? Can somewhat babied and never beat
My recommendation is that you replace the entire distributor. My guess is that this will solve the original problem.
Thanks Ron... Also, what distributor would I need? 1993 EX. Is that a TD-42U? Any reputable places I should be looking at to buy?
OK... replacement distributor came in.. I put it on, reconnected all wires and no start (yet). I only tried twice.. one was a slight backfire. Now, what I am wondering... i have read where the dizzy can only go in one way, correct? I mean, the shaft of the dizzy (or key) cannot go in upside down (180 degrees off), could it? I just want to make sure before I go nuts over this.
UPDATE - Got it running this morning... So far so good. Took it for a long ride and no stall after it reached normal operating temp. So if anybody h ad the same symptoms, def check your distributor.
BallroomDancer1
Honda Civic (2016 - Current)
01-02-2017 08:40 PM
onebadfntsi
14
05-26-2013 09:51 PM
dmxsoulja3
12
12-24-2004 11:55 AM
