Broken lock...inside
The door-lock on the inside of my drivers side door(93 eh3) just broke. It just flops back and forth. Is that common?
It has power door locks installed. But I can only unlock them with my remote, not manually.
Whats the part number for that piece?
Re: Broken lock...inside
im pretty sure thats not common
i recently broke my del sol drivers door handle to
take off the door panel and check to see if the plastic part that connects the door handle to the wire to unlock your door is still attached
if the plastice is broken you need a new one,
if its unattached then just attach it back,
sorry but i don't know the part number, just look for one at your local pick and pull
Oh look, I can change this
Pretty common -- had it happen on a 92 VX car I bought. Grab one from a junkyard - it's an easy fix. Also, make sure that the power locks aren't stressing the lock when you activate them... it will chew through locks like nobody's biz
doklo
04-06-2021 03:54 PM
Superchick9235
01-27-2012 01:28 PM
toben
02-24-2007 08:05 PM
