Ground Problem
Ground Problem
I recently pulled my starter and distributor from my eg. After reinstalling, car will not start. It was turning over kinda week and would sputter for a second. I then realized while it was cranking the main relay was continually clicking. I swapped it out for a known good one with the same results. Also noticed that my inner brake lights are not working as well.
Thermostat ground, valve cover ground, and tranny ground are all on. Any other grounds that I could be missing??
Technical Hero
Re: Ground Problem
sorry this is the best pic I could find but under the bigger boot On the starter there is a nut, make sure it's not loose, I've had the same happen before where it was loose and the relay was clicking
sirrex1990
05-13-2010 06:29 PM
Fuzion
09-03-2004 12:08 PM
