1999 civic SI- does it have ABS in rear
New User
My '99 civic si has the ABS option, does this mean only in the front, or all around. Its got discs all around. Only answer if your sure. gotta replace rear wheel bearing and need to know which part to order. thanks
Re: 1999 civic SI- does it have ABS in rear
look on the back side of the hub and see if it has a sensor im pretty sure its just front wheel abs i could be wrong tho.
Crazy Honda Guy
In the US, the Si did NOT have ABS option
In Canada, the SiR (same as US Si) did get the ABS option standard which has sensors at all 4 wheels
1 Post
Where do you live?
Kinda creepy question huh?
JK the reason why i ask is because the civic si (usdm ex)and civic si-r( usdm civic si) came with abs all around.
We didnt get abs in the states
if you have a CANADIAN civic sir coupe the abs came as standard...If you have a U.S civic si coupe it was an option and DID NOT come on the car standard,factory what have you....just 4 wheel disk brakes. So if the light on your car if your certain (check and recheck) says abs and not srs by the tach when you first start the car then you just might have a canadian civic coupe.
