e brake
Re: e brake
theres deffinetly not air in the lines.
jack the car up and take the wheel off, have somebody pull the ebreak up, while you whatch the caliper, does that spring thing move?
Re: e brake
Do what the other poster suggested and remove a rear wheel and have somebody else pull the parking brake and see if the cable is moving the spring on the brake. Then do the same thing on the other rear wheel.
Re: e brake
I forgot to add, if the spring on the brake does not move when the parking brake lever is pulled, then you need to replace the parking brake cable.
Re: e brake
jack your car up take the brake rotor off and at the top of the hub there should be something known as a star cylinder which probably needs to be adjusted to the point were you can barely slip the rotor over it!
HondaHeddie
11-11-2006 04:20 PM
Kennydee
10-29-2006 08:22 AM
