B18C-R swap
B18C-R swap
So...I'm currently prepping to do a B18C-R swap in my 94 EG. And was wondering which certain parts I need. I know I need the obvious B18C-R engine, tranny, ECU, B-series engine mounts, and OBD2 to OBD1 jumper wires. But as to which axles, half shaft, and shift linkage I have no clue. And if there is anything else that I'm missing please let me know. Anything will help me out right now! Thanx!!!
Re: B18C-R swap
well main things other than what u listed are this for a eg swap to b
1. Dc teggy linkage
2. obd1 vtec harness for motor (can be wired in)
3. u need Dc axles and half shaft
4. 94-01 tegg 5spd rear T bracket
5. stock dc/eg mounts them selves or just buy hasport or avid mounts what ever ur budget is
think that is about it that i can remember ATM
1. Dc teggy linkage
Re: B18C-R swap
Make sure you get a half shaft for a 5 speed B series and NOT an automatic. The auto will NOT fit with the 5spd trans. You can use the axles & half shaft from any of the following vehicles:
94-01 Integra (any model)
94-97 Del Sol VTEC (DOHC)
99-00 Civic Si (DOHC VTEC)
You can mix & match them from any of those cars. The axles can be from an automatic trans Integra, but the half shaft HAS to be from a 5spd trans.
The rear trans "T" mount bracket also can come from any of those above cars as long as if from an integra it's a 5spd.
Shift linkage from either a 94-01 Integra or 99-00 Civic Si (DOHC VTEC). You could not use the linkage from a Del Sol VTEC (DOHC) because it is different.
Torque mounts have to be off of a B-series. The D-series torque mounts will not bolt to the B-series block or trans.
Radiator & heater hoses from Del Sol VTEC (DOHC). Integra GS-R & Type-R radiator & heater hoses MAY fit the 92-95 Civic, but I can't remember for certain at this time.
It will be easier to use an OBD1 VTEC engine harness than trying to wire in an OBD2 engine harness.
nolanator6
03-02-2011 03:17 PM
