h22 eg help
h22 eg help
ok heres my story im going to try and keep it simple without getting too many people confused..
so i got a eg with a jdm h22a swap in it, so the last one had a rod nock, so i bought one from tigerjdm, got here in 4 days.. so got the new engine installed, used old harness, couple sensors (were broke kinda expected that), clutch, flywheel, fuel rail,
anyway so i go the new one swapped in, need to hook up the axles,and do a ball joint, went to crank it and fried out my starter, so i got a new one and its acting like it doesnt wanna crank over,
so i undid my header and rotated the crank a few times and the ******* pouring gas out of the #1 cyl..
any ideas? i do have spark also..
im beginning to think the injectors gettn stuck open, i didnt use my old injectors these are the jdm ones.
any help will do .. im tired of beating my head over this car
Re: h22 eg help
pouring gas out of a cylinder?? elaborate!
its super easy to swap injectors if you think thats whats wrong.
should still fire, even if one cylinder is full of fuel
Re: h22 eg help
its only doing it out of the number one cylinder, i was cranking it by hand counter clockwise, i looked under my car and it was pouring something out the exhaust, on the compression stroke .... so i took the header off, and took all the plugs out of the motor
continued to rotate after took the plugs out and i heard a loud gush and it shot fuel thru the exhaust port and the hole for the plug...
( the starter was garbage b4 the swap i forgot to ad it just burnt out when tryin to crank it)
Re: h22 eg help
if you have a cylinder thats full of fuel, an injector would be the first thing I would look at. instead of inspecting them, just swap them for the ones you know are good. (from your other motor).
sloshing around huh, hmmm... thats a lot of fuel.
Re: h22 eg help
ok ill try that intector , and let u no how it turns out, its a ridiculous amount of fuel, and it doesnt make sense y it is only 1 cyl
