WOnt Start Help!!!
WOnt Start Help!!!
okay have a 93 bubble dx version and i swapped in a single vtec motor and used my old harness which is a non v harness and it wont start....motor wont even turn over....that harness doesnt have a map sesnor plug but i dont think that should stop it from turning on and also its a non v ecu it should still turn on but throw codes till i can rewire the vtec..... could that starter be bad
Re: WOnt Start Help!!!
ur missing something...check all connection on shock tower, by the battery, driver side shock tower
check all grounds, trans to frame, valve cover to radiator support, n thermostat
Lololololol. First off, bubbles are round and clear. Your Civic hatch is neither.
Second, "wont start" is used to often. Will it turn over and not start? Or is the starter not operating?
Third, you DO have a MAP sensor plug. If it doesn't it's either been cut-off or plug up in the wrong spot.
Lastly, check your connections and grounds.
I pity the one who never played with lego's. Later, BR
B18CivicEH2
05-06-2009 05:29 PM
