lsvtec oil leak between head/block under dist.?????
I had a small oil leaked on the headgasket right under the distributor side between the head and the block, so I had the headgasket replaced and got the head resurfaced with new valve stem seal, also put in a str cam seal.
After got it running for a day, noticed that the leak is starting to show again, after a few high rev on the highway, noticed that its getting on the wires and little splash hitting the intake. Everything is cleaned of oil and dirt on the head, only where head meets block down there's oil, dirt etc...
I replaced it with a stock LS hg and im pretty sure I got it on the right side because the other side, one corner doesnt line up with the block.
Re: lsvtec oil leak between head/block under dist.?????
ls-vtec all way leak oil between the head and block. it could be your distributor is not tighten enough, also check your vtec VTEC solenoid gasket just in case. by the way what kind of head gasket did you used??
Best way to do it, clean which side the oil comes and after that let your car idle and have a look which side the oil comes.
Have you check your Distributor seal? Or Cam seal?
Cam seal or distributer o ring, pretty sure its the dist o ring.
^ my first guess as well
best bet is to clean the **** out of it and let it idle... attack at first sign of oil
Cleaned it off, and noticed that the oil starts to build up where the tranny and block meets, so sounds like an oil line is leaking slowly to where the tranny and block meets but I cant distinguish extactly where its coming from other then center of the head and block meets where it ditch in , because cant really tell if its leaking from there with everything blocking it.
any input?
any input?
I HAVE THE EXACT PROBLEM WITH MY LS V, EXCEPT THE OIL LEAK HAS GOT A LOT WORSE OVER TIME. TO THE POINT WHERE ITS LEAKING OUT OF CONTROL AND I HAVE TO PULL OVER CUZ ITS STARTING TO LEAK ONTO THE EXAUST MANIFOLD AND STARTING TO SMOKE. ANY HELP WOULD BE APPRECIATED. ANY IDEAS?
Fixed the oil line leaked and its still leaking.
The motor was already leaking little oil when I bought the car so im not sure if they used the kit or not.
During the install, the dowel pin only fitted on the intake side of the head because the hole on the ls gasket were too small on the exhaust side so I used the intake side to line everything up with the arp studs.
The dowel pin were same size on both ends, so they must of drill the head to fit the dowel pins?
This only comes down to one thing, either my block is warped, uneven or??
pooRmansss
02-19-2009 03:24 PM
JDMlyfestyle
28
07-20-2006 04:20 PM
