d16 sticking idle problem
here's as detailed as i can get
Patient: 94 civic ex coupe 5spd
d16z6 with 150k miles
100% stock engine
symptoms: car idles normal as its warming up
once car is @ operating temp, will average around 900 rpm
when i rev the engine or drive the car, it behaves normally
when i slow down and let off the clutch, the idle sticks from 1.5k-2.5k
i have to pull the pedal BACK with my foot to make the engine idle at regular rpm
attempts: sprayed the TB butterfly valve with carb cleaner in case it's sticky
took off the IACV and cleaned it with carb cleaner (although this DID eliminate the idle problem, it shortly returned the same day)
can anyone help?
100% stock engine
can anyone help?
Re: d16 sticking idle problem
I have exactly the same problem on my 99 Accord.
I thought of cleaning the throttle body and valve.
however, I noticed that the throttle pulley or butterfly does not return to initial position when releasing the gas pedal. It returns to a position that is few degrees before the idle position. I noticed that the pulley bolt was a little bit loose ... I tighetened it a little bit and the pulley now goes back to the idle position right after releasing gas pedal.
I did not try the car yet on road as I have some other parts to clean and replace. But this little idea may help you.
i havent inspected my throttle pulley bolt yet but i will tomorrow.
thanx for the reply and sorry for the late reply
R. Mack
06-01-2005 07:55 PM
Jet Black
12-29-2003 05:32 AM
