LS CRANK GSR CRANK THE SAME?
HI IM REBUILDING MY GSR MOTOR.. AND I WAS WONDERING IF A LS CRANK AND GSR CRANK ARE THE SAME.. OR IF I CAN USE A LS CRANK ON A GSR MOTOR??
THANKS
THANKS
Crazy Honda Guy
Re: LS CRANK GSR CRANK THE SAME?
They are not the same.
ls crank gives a 1834cc displacement
gsr is 1797cc
using an ls crank can be done, but you will have to double check clearances, you may need to modify your setup a bit to make it fit
gsr is 1797cc
