Idle air control valve issues!!
Old 07-24-2010, 03:36 PM
Andrew14's Avatar
Default Idle air control valve issues!!
I have cleaned my IAC valve several times with carb cleaner and pluged out the battery and still my car idles high after a couple driving. I would drive and then put my car in neutral and my idle is at 1300 rpm. I don't know what to do from here. Any help is much appreciated.
Old 07-24-2010, 03:41 PM
tomd15's Avatar
Default Re: Idle air control valve issues!!
have you replased the dizzy/
Old 07-24-2010, 03:44 PM
Andrew14's Avatar
The dizzy is not the problem because after i clean my IAC valve it runs good until another day when i start my car again it acts up.
Old 07-24-2010, 03:45 PM
BrandonR's Avatar
Have you checked for vacuum leaks? If so, then just replace it. It's probably long past it's service life.
????? -Later, BR
Old 07-24-2010, 03:59 PM
Andrew14's Avatar
where are the vacuum lines on my car.
Old 07-24-2010, 04:01 PM
Andrew14's Avatar
the two lines that are located under the IAC valve are good coolant flows through them like its suppose to.
Old 07-24-2010, 05:54 PM
Andrew14's Avatar
anyone!!
Old 07-24-2010, 07:58 PM
madracer's Avatar
Buy a new Iac Valve from Honda, that will fix your problem, its a little pricey but well worth the trouble. I dont go through the cleaning issues with the iac anymore because its a hit and miss situation.
Old 07-24-2010, 08:04 PM
Mad-Mike's Avatar
My IACV was bad on my em1 so I just bought a new one from autozone for around $180.
Old 07-25-2010, 08:30 AM
Markley02's Avatar
I would look into the FITV before you buy a new IACV.
When your idle is high keep the motor running while you take off the intake tube. Cover up the lower hole inside your throttle body with your finger. If the idle fixes itself when you do that then it is your FITV.
Old 07-25-2010, 09:38 AM
Former User's Avatar
What year and engine?
Old 07-25-2010, 11:22 AM
Andrew14's Avatar
93 civic 4 dr with d15b7
Old 07-25-2010, 11:34 AM
As mentioned, clean and adjust the FITV. Click FITV in my signature.
Old 07-25-2010, 11:59 AM
Andrew14's Avatar
What is the FITV
Old 07-25-2010, 12:07 PM
Did you click the link?
Old 07-25-2010, 12:25 PM
Andrew14's Avatar
i see it now thanks. so basically just clean that and the IAC valve and restart the battery and see what happens there.
Old 07-25-2010, 12:28 PM
Yes, but the FITV should also be adjusted.
Old 07-25-2010, 12:35 PM
Andrew14's Avatar
so can't i just tighten it all the way and if it idles to low just adjust from the throttle body or i have to adjust it from the FITV
Old 07-25-2010, 05:57 PM
Markley02's Avatar
You can tighten it all the way down, but I would do it 1 1/2 turns out. To save your self time though I would test it like I said earlier!
It takes about 20 seconds to take off your intake and it is a 100% foolproof way to see if it is your FITV! When your car is warmed up there should be very very little to no air going into that lower hole.
If it still has a bad idle while covering that lower hole, try covering the top hole. When you cover the top hole the car's idle should drop ALOT! It should even die. If it still idles with the top hole covered you have a leaking vaccum line somewhere. If the car does die it is a 95% chance that it is your IACV or TPS. Probably IACV.
Old 08-17-2011, 02:30 PM
ej1619's Avatar
ok so my car 93 civic d15b7 had a really low idle like 500 or less when warmed up. i cleaned the iacv let it dry for an hour then put it back on. after it was put back on it now idles from like 700 to 1300 rpm??? wierdill try and post a vid. any help would be great
Old 08-17-2011, 05:01 PM
Does the idle drop if you cover the hole to the FITV?
95gsr@530
05-13-2019 10:43 AM
Ge-money
08-07-2006 01:05 PM
ATS*Mark
16
02-22-2004 01:00 PM
specalk
12-24-2003 09:09 AM
Hondaaccordvtec
05-19-2003 06:13 PM
Quick Reply: Idle air control valve issues!!
