1992 Honda Civic - Cluster Lights Not Working
I recently purchased this car and noticed at night the cluster lights do not work.
I have check all the fuses and its still not working.
what can i do to get the lights to work or any ideas?
I tried to search the forum for any previous threads but wasnt successful.
Re: 1992 Honda Civic Cx
Double check 10A dash fuse 19. A blown fuse does not always look blown.
If the fuse is fine, check the three wires (Red, Red/Blk, and Blk) in the dimmer switch connector. The Red and Red/Blk wire should measure battery voltage to body ground with the Parking Lights switch on. The Blk wire is ground and should have continuity to body ground.
ok...i will replace the fuse and check the wire on the dimmer switch.
So..the the dimmer switch supply's power to the cluster for it to light up?
OP, do the heater control panel lights work? If so, it could be a cluster or cluster wire problem. However, if both the cluster and heater control panel lights don't work, do the troubleshooting I mentioned.
clock, heater control, radio....all work.
I will try swapping out clusters and see if that fixes the problem.
You mean the back lights, right? Do they brighten and dim with the dimmer switch? If so, check the Red and Red/Black wires/terminals in the cluster connector. Do they have battery voltage? Are they damaged?
i temp fixed mine by unplugging the dimmer and bridging the wires with a paper clip. i left it that way because im cheap and lazy but its a way to test it without buying a new dimmer switch.
i will try this and see if the cluster lights up at all.
Global Moderator
1) No one will read a thread without a subject specific thread title, you have a better chance at replies with a more specific title
2) This will never be found in the search engine.
Read stickies before you post.
Re: 1992 Honda Civic - Cluster Lights Not Working
you can just do what i did and wire in an led light strip from an open spot on your fuse board to your dash. will post pics of my set up tomorrow. going out tonight to get pics take of mah whip at night!
i think i may have to do that if i cant figure out whats wrong.
where can i get a l.e.d strip from?
swapped out all the wires that go to the radio, dimmer switch, cluster, hazards and clock.
Now my cluster lights work. yeeeeee hawwwwwwwwwwwwwww lol
mark11017
09-27-2010 09:17 PM
LOLyouhavefakewheels
11
02-01-2006 07:28 PM
