Fan does not come on 1998 civic EX
I checked it out a couple days a go and my fan wont come one. Would the Thermostat switch cause this? i check the fuses related to the fan as well as the relays and they all seem to be fine. The car has ran hot before and over heated a coulpe times so im wondering if this would render the switch useless?
Thanks!
Thanks!
Re: Fan does not come on 1998 civic EX
Is the engine overheating? If so, under what conditions?
Fan switch:
Unplug the 2P connector to the fan switch on the thermostat housing and then short the two terminals in the wire harness connector with a jumper wire. With the key in ON(II), does the fan now run continuously? If so, you may need a new switch or the cooling system needs to be bled.
Fan switch:
Fan switch:
Fan switch:
Im off to the stealership for a new T-stat.
Did what you suggested with the jumper wire on the connector to the fan switch. It turns on when i jump it but does not when plugged in. I replaced the Fan switch and still nothing. Car hasnt over heated but still curious as to why the fan wont come one. I installed a OEM T-stat as well.
Bleeding may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
well if it still doesnt come on it could be the temp switch. Mine went out aswell so I just jumped it, its been jumped for years now with no issues. Just get a insulated wire and plug it into the plug, and then cover it with electrical tape and put it somewhere. Maybe one day I'll replace it lol
lol i must be too tired today to realize ****. It wouldn't make sense that it doesn't come on unless there is a abundance of trash built up inside of the coolant system that is somehow preventing it from working :/
Thanks for all the info guys! The temp switch is the one that tells me how hot my egine is yes? The fan switch it a whole diffrent switch yes? if so i just replaced the fan switch located at the thermostat housing. im gonna drive the car some more today to see what happpens with the engine temps. I really dont want to re-do the headgasket. If so im gonna do a Vtec head swap as the original motor was a y8 but now it has a non vtec D15b.
jry2598
08-28-2006 10:19 AM
