b16a3 in eg mount question
I'm about to swap a b16a3 from a delsol into my eg hatch and am wondering what mounts to use. i dont have the money right now for hasport or innovative so i was wondering which oe mounts i can use. one friend says that stock mounts work, other says that i need a mount from an integra. any help is appreiciated. thanks.
Seagull Management
Re: b16a3 in eg mount question
You can use all the mounts from the Del Sol, you will however need a shift linkage from a '94 - '01 Integra, the Del Sol linkage is too long (its also worth some money)
Seagull Management
If its coming from an EK you can't use any of the mounts other than the brackets for the front lower torque mounts and the torque mounts themselves. Rear T/L bracket needs to come from a '94 - '01 Integra or '94 - '97 Del Sol VTEC. Timing belt mount you can do one of two things, you can use the 2 post mount thats on it and use a stamped steel D-series mount, or you can swap out the timing belt mount for one from an integra in combination with the Integra aluminum mount. (really you could just trade your friend for his ITR mount because he wont be able to use it in an EK, assuming it came with mounts) Upper transmission mount needs to come from a '94 - '01 Integra, '93 - '97 Del Sol or '92 - '95 Civic. Thats right, the D-series upper transmission bracket is identical to the B-series variant, just make sure it came from a 5 speed. If you plan on running air and power steering get the lower A/C bracket from a '94 - '95 Del Sol VTEC.
Seagull Management
The rubber lower torque mounts will be retained, but the brackets need to be from a B-series.
