2000 si comp test results
Old 07-24-2010, 12:51 AM
jdmitrdc2's Avatar
Default 2000 si comp test results
is this good for a 2000 b16a2
#1-180 #2-185 #3-190 #4-194
Old 07-24-2010, 01:23 AM
Crazy Honda Guy
Deetz's Avatar
Default Re: 2000 si comp test results
well, for a good engine to run nicely, it really should not be out more than 10psi between cylinders
Old 07-24-2010, 01:29 AM
pm4nudes
chewyv's Avatar
Old 07-24-2010, 08:53 AM
vanilla_rice's Avatar
rule of thumb I had always heard was less than 10% difference between max and min means you're good.
Old 07-25-2010, 01:13 PM
Dale_K's Avatar
The Haynes manual says the standard B16A2 should have 184 psi compression and the minimum is 135. The maximum allowable variation between cylinders is 28 psi per Haynes. The factory shop manual doesn't list a pressure but matches Haynes concerning the 135 minimum and 28 pound variation.
Old 07-25-2010, 01:23 PM
Sr420Det's Avatar
yeah those are decent numbers, u did hold the throttle open, right?
Old 07-25-2010, 01:49 PM
jdmasfuk's Avatar
seems kind of high.. i did mine not to long ago and was between 160-165.. Is the engine stock?
Old 07-25-2010, 02:30 PM
Former User's Avatar
I agree
Old 07-25-2010, 05:46 PM
Markley02's Avatar
Could be better, could be a lot worse. Probably not really worth doing anything about it. If you want, do a leak down test.
Old 07-25-2010, 06:18 PM
Sr420Det's Avatar
really i was thinkin kinda low, all my motors (b16s, d15b, d16z6, b20z was 220) are around 210
Old 07-25-2010, 11:53 PM
jdmitrdc2's Avatar
it has 155000 miles on it has a short ram aem intake but other than that its stock.the thing is i forgot to hold the throttle open while i checked it
Old 07-26-2010, 06:19 AM
^The test must be done at WOT.
Jm920
05-04-2015 03:10 PM
hondacrx2
09-01-2010 02:33 PM
Si_chRis
15
05-26-2006 08:46 AM
lude98SH
11-12-2005 06:21 PM
sCeRaXn
10-09-2002 04:43 PM
Quick Reply: 2000 si comp test results
