Climate Fuse Blows - Please Help
Ok,
So the saga for the 93 DX continues... I'll try to keep this short. When I purchased this vehicle, ALL the lights of the climate control box worked, but the A/C switch died. Since then I've a) Removed the air conditioning (engine swap) and b) Just replaced with a known working Climate Control. However, the same issue occurs. I turn the car on, the climate control works. When the car is ON, the climate control can be on any setting, or off, it will randomly blow the fuse leaving me with no air movement (which is bad during rain/cold!). This is a major issue.
As far as the clues:
1) I replaced the dimmer switch as it was intermittently making my dash lights go on and off, although it doesn't seem to be directly connected to the Climate Control, ever since I replaced this.. The lower lights of the climate control (where the heat setting is, there are two bulbs behind it) stopped working - BUT It took roughly 6 months AFTER the dimmer switch change for the climate control to blow its fuse.
2) It doesn't matter what setting the climate control is on, and it can even be off for it to die on me.
Thanks for your help in advance!
Re: Climate Fuse Blows - Please Help
To avoid wire damage and a fire, never install higher than recommended amperage fuses.
You obviously have a short in the fuse 13 circuit. The best way to pinpoint the short in the circuit is to unplug each component protected by fuse 13 one at a time to see whether one unplugged component prevents the fuse from blowing. You will need to buy a box of 7.5A fuses.
The first diagram below shows all components protected by fuse 13. Start by unplugging all 5 relays on this circuit at the same time.
-If this prevents fuse 13 from blowing, then unplug each relay one at a time to identify which one prevents the fuse from blowing.
-If fuse 13 still blows, then unplug the mode control and recirculation motors and the heater control panel. If fuse 13 now does not blow, then unplug each component one at a time to pinpoint the source of the short.
Fixed it. It was either the old AC wiring harness relay in the front of the car or it was the fan relay... either way it's working great now. Thank you so much for your help!
mormonboy
09-07-2007 10:24 PM
