I think i blew a fuse NEED help!!!
well i was driving and my friend was behind me and he called my cell and said my brake lights wernt working....so i was like damn ill pull over and make sure everything is connected, on my way pulling into the gas station i went to honk my horn and the horn didint work either you think this is fuse related!!!!
Re: I think i blew a fuse NEED help!!! (Silverstone00Si)
check the fuse box under the steering wheel.... read the chart and check for your fuse.. if still confused, pull all fuses and replace blown fuse
Re: I think i blew a fuse NEED help!!! (Rhythm Racer)
also, check the underhood fuses as well. i'm almost positive there is a brake light fuse under there too.
does the horn relay still click when you press it?
Re: (Dohc93hatch)
Thanks for all the feed back but i think im just gonna go ahead and replace all the fuses... fuses are cheep and the fuses havint been replaced since 96 so what the hell!!!! thanks
Re: (Rhythm Racer)
the horn fuse under the hood controls the brake lights too...what happens sometimes is that if the horn wires gets pinched it'll blow that fuse and end result losing horn and brake light...2nd gen and 3rd gen integras are like that i believe
Re: (Rhythm Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhythm Racer »</TD></TR><TR><TD CLASS="quote">Thanks for all the feed back but i think im just gonna go ahead and replace all the fuses... fuses are cheep and the fuses havint been replaced since 96 so what the hell!!!! thanks</TD></TR></TABLE>
Really not neccesary to replace them all, but do what you will. Just look for the blown one and replace it with the right amperage fuse.
Yager-
Yager-
tdubbebawllin
07-29-2008 01:34 PM
OptimusPrimeX
02-03-2004 02:37 PM
