where is the coolant drain bolt?
Re: where is the coolant drain bolt? (blueeg)
i believe the only coolent drain bolt is on the radiator...
it should be at the very bottom either on the right or left side...
OG triple OG
Re: where is the coolant drain bolt? (EK-TUNED)
i believe there is only one on the radiator , its on the bottom right its a wingnut , if there is one on the block that would be great.
Re: where is the coolant drain bolt? (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI »</TD></TR><TR><TD CLASS="quote">Behind the headers - Giant pain in the butt to remove...</TD></TR></TABLE>
i think you're wrong (or you're refering to a v6 ). its on the back of the block by the oil filter. this topic came up earlier.
from a 96-98 helms manual:
also there is no mention of engine specific differences here, so i'm assuming the bolt is there for y5,y7, and y8 engines. i know for a fact that's there it is on my y8. to loosen it, try getting at it from underneath the passenger side. if you go directly under it, the axle is in the way. still a pain in the *** either way, and coolant gets everywhere, so have a beer bong like contraption up there.
Modified by jwn7 at 11:42 AM 1/22/2004
ehonda1980
08-01-2007 12:18 AM
ehonda1980
07-31-2007 11:26 AM
