Code 15 Problem ?
Old Jun 25, 2003 | 03:07 PM
CiViC SiR's Avatar
Default Code 15 Problem ?
I have code 15 (Ignition Output Signal)
missing or defective ignition output signal
what should i check?
Old Jun 25, 2003 | 03:52 PM
Turbo92Si's Avatar
Default Re: Code 15 Problem ? (CiViC SiR)
had same problem the other day......ended up my distributor was all messed up inside and a few wires were apart. Could also be a bad coil or igniter.
Old Jun 25, 2003 | 03:59 PM
eg6ajk's Avatar
open the distributor cap check out the wear on all components. use a little bit of dieelectric grease on the terminals inside and outside. and retry this might help the situation.
SMZ GSR
Jun 7, 2005 05:40 PM
shorty91
Jun 27, 2003 07:55 PM
CiViC SiR
Jun 26, 2003 07:07 AM
CRexDX
Apr 10, 2002 06:37 AM
