EG9 cluster help!
EG9 cluster help!
I am swapping a jdm eg9 cluster into my civic. I want to swap over the SRS module as well. I did a search and most people said that the easiest way is to remove each gauge from the rear then snap in the SRS module. Looking at the rear of this cluster, I don't see how I can remove each gauge assembly? Behind the fuel/temp guage theres a plastic box with 2 phillips screws. I guess this would remove that gauge. But how do I remove the other two? Theres a bunch of other screws on that electrical contact sheet? at the back, do I remove all of those?
Thanks.
Thanks.
Re: EG9 cluster help! (johncivic)
oh and my cluster is an automatic one. I can remove the assembly from the only for the auto shift lights. But I need to get the speedo out from the to put in the SRS. But the speedo isn't like the gear lights, so how can I get my SRS assembly in?
Ok, I tried this now, I can pull the entire back off by snapping out the 3 clips on top and the 3 clips on the bottom. This seperates the white back from the bezel/clear plastic front. The problem now is I can't get the entire thing seperated because the trip meter reset is in the way. How can I get this out, I tried turning it but it doesn't screw out?
Sounds like you want one of your more mechanically
inclined friends to help you on this.
The black cap on the
trip meter pulls off. Take off the auto stuff and then
there will be screws on the back, like 4-6 for each gage.
I have 2 gage clusters for sale now. The link is in the Sig.
SC2.2CL
03-29-2006 11:03 AM
