compression problems
Old Jul 16, 2003 | 01:58 PM
juicedricer's Avatar
Default compression problems
ok i did a compression test about 2 months ago when i did my water pump. then it was at 185-170-170-170........... now i recently did one because the car hasnt been pulling the times it was in the beginning of the season. now, 185-175-165-155. can anyone tell me where i am loosing compression at? is it the piston rings? or maybe could it even be a leak in the headgasket that could cause it??? also if it is the piston rings what procedure would i go through to replace the rings since i am replacing rings should i just get a set of CTR pistons or an aftermarket set???
any help on what might it be would be is appreciated
Old Jul 16, 2003 | 02:10 PM
Default Re: compression problems (juicedricer)
also what is a good site to buy piston and ring set or even a pistons set w/rings and rods?????????
JJDub
Engine Machining & Assembly
May 31, 2017 07:30 AM
NegativeXero
Nov 10, 2007 03:57 PM
Vpenh
Aug 8, 2006 02:49 PM
2 0 3
May 6, 2006 04:23 PM
juicedricer
Jul 19, 2003 12:07 AM
