peeps w/EK hatch & SI tower bar...
i'm gonna have to drill the holes at the mounting points huh? i see cut outs but no holes...DAMN these cx's are cheap. i also have to drill out the hole for the cold air...and i see a cut out for the secondary o2 under the car...but AGAIN no hole. bottom line is...whats the best way to do it?
Re: peeps w/EK hatch & SI tower bar... (Jackson)
did you need to like take the wheels off and all that? or are the holes clear to see from below. did you get hondas hardware(nuts & bolts) or did you use your own?
Re: peeps w/EK hatch & SI tower bar... (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX »</TD></TR><TR><TD CLASS="quote">and i see a cut out for the secondary o2 under the car...but AGAIN no hole. </TD></TR></TABLE>
check again. on my 97 hatch in the o2 hole there was a plug. when i put in my y8 swap and exhaust i just popped out the plug and stuck the wiring in like normal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX »</TD></TR><TR><TD CLASS="quote">did you need to like take the wheels off and all that? or are the holes clear to see from below. did you get hondas hardware(nuts & bolts) or did you use your own?</TD></TR></TABLE>
I jacked up the car and left the wheels on. I used honda bolts and nuts I had laying around.
vietshinobi
16
03-12-2008 12:31 PM
phiberoptik
06-08-2004 12:43 PM
