Will 2000 Civic EX front LCA's work for swaybar in 99 hatch...
I need to know If I can use 2000 Civic EX front LCA's opposed to Si LCA's for a ctr/itr swaybar up front. Let me know. And will it be compatible with Si front knuckles? I assume I will need EX shock forks as well. I need to know quickly becaus I am supposed to call the guy back in a few. Your help is appreciated.
Re: Will 2000 Civic EX front LCA's work for swaybar in 99 hatch... (IDriveHonda)
No, if you want to run the SI 26mm front sway bar you will need, SI control arms, SI endlinks and SI shock forks as well as the sway bar and brackets. IF you want to run the EX 22mm front sway bar you do not have to get any new shockforks but you will need the ex control arms. hope that cleared things up.
SHG_Beans
06-30-2008 05:23 PM
BanEL
03-20-2004 06:33 AM
Takeoff
10
12-21-2003 06:59 AM
