pwd door lock/unlock wires in 95 del sol
I just installed my alarm and everything works except lock and unlock function.
I used Green/White for lock and Green/Red for unlock and connected directly to the wires from alarm main unit.
and this is where i splice the wires.(circled with blue pen)
are these right wires and right location to connect?
Re: pwd door lock/unlock wires in 95 del sol (bearboy80)
id like to know why in the hell my doolocks on my civic dont work, there is power to everything, they just dont unlock or lock
Re: pwd door lock/unlock wires in 95 del sol (Simple)
i know that you shouldn't use those quick-connect thingy...the guy that does all the alarm installs for my shop solders everything, and yelled at me when i attempted to put my alarm in and used those things...says they are very bad...can cause fires. wait, that's what those little fire extingiushers are for, isn't it?
Re: pwd door lock/unlock wires in 95 del sol (EG-cellent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-cellent »</TD></TR><TR><TD CLASS="quote">Should be white with black stripe(+)
green with red stripe(-)
Under dash behind the cruise module.</TD></TR></TABLE>
+ is white/black? i checked the12volt.com and bulldogsecurity.com and they both say Green/White (-), Door Unlock Green/Red (-) and honda used - wires. not +. can you double check? thanks
I checked and you were right on the colors and polarity.
on me,one of our books was wrong and the other 2 had the same colors as you did.
I would check to see if it is part of the programing.
95 Civic 2dr coupe
I never narc'd on nobody!
12 year old thread.
12 year old thread.
You've already been told by a moderator once. Stop bumping ancient threads. You've been around long enough that you should know better. If you have a direct question for a member, send them a PM. This guy hasn't even logged in in over 2 years - what makes you think he's going to magically show up just for you?
12 year old thread.
Again, please create your own thread rather than bump ancient ones. See the forum Rules.
B-Rabbit20
Audio / Security / Video
40
08-21-2015 10:53 AM
