AC Setup for B20 EG
AC Setup for B20 EG
Well I'm outta SoCal and if you don't know it's getting hot as hell so I figure it's about time to throw the AC back in the ride. I have a 93 hatch with a B20 setup and I need to know what components I need to get my AC back up and running. I was told that I can use my single cam compressor and I just need to buy a del sol bracket to mount it on my block, but if anyone out there is running this setup and has AC, or knows what I need to make this functional, please let me know!!!
Re: AC Setup for B20 EG (pbinteg99)
92-95 compressor for sure. you might be able to use 96-00 except si's. i have heard that you can use a b20 bracket but if not del sol vtec's (p54) bracket.
Mr. Badwrench
Re: AC Setup for B20 EG (O.G triple O.G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O.G triple O.G »</TD></TR><TR><TD CLASS="quote">92-95 compressor for sure. you might be able to use 96-00 except si's. i have heard that you can use a b20 bracket but if not del sol vtec's (p54) bracket.</TD></TR></TABLE>
the delsol vtec bracket will allow you to use you a/c compressor that already is in your car.
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Use the car's stock compressor and hoses and a Del Sol VTEC AC bracket...but be prepared...I payed $150 for the bracket from the dealership...but the AC is so worth it.</TD></TR></TABLE>
Whoaaaaaa!!! I only paided $50 for mine.......I used a CRV bracket for mine and it worked prefect...the CRV uses a single cam compressor, but u can use a Del Sol DOHC one too.
Re: (eg cookiemonster)
you guys are all crazy. i have a 95 eg hatch with a b18b and i used the b18b compressor and b18b mount and had my civic hoses redone. it cost me 40 bucks a hose or less. screw using the sohc compressor switch to the dohc one!
Re: (civicflnum1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicflnum1 »</TD></TR><TR><TD CLASS="quote">you guys are all crazy. i have a 95 eg hatch with a b18b and i used the b18b compressor and b18b mount and had my civic hoses redone. it cost me 40 bucks a hose or less. screw using the sohc compressor switch to the dohc one!</TD></TR></TABLE>
why go through all the hassles?? just use a del sol dohc vtec one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg cookiemonster »</TD></TR><TR><TD CLASS="quote">
why go through all the hassles?? just use a del sol dohc vtec one</TD></TR></TABLE>
what hassle? i drop off my car at an a/c place give em 80 bucks and they make the lines and everything another 30 or so to fill it up with freon and i walk away with nice a/c. i think getting custom hoses made is easier than switching brackets and everything (easier cause i dont have to do it lol)
Pac-Man_G
11-11-2008 09:51 AM
wizzards581
03-30-2004 05:55 PM
