Axle Problem!!!! HELP!!
Re: Axle Problem!!!! HELP!! (Egone)
https://honda-tech.com/zerothread?id=382416&page=1
im on step 15
im on step 15
Re: Axle Problem!!!! HELP!! (im_poor)
I just swapped in a b16 in my hatch and i reversed the axles which made one side go in all the way and one side go in about an inch. I realized it was going in any further and pulled both out and inspected them. One azle had splines running down the whole length of the shaft that slides into the tranny and the other had splines on half of the shaft. I then switched the axles and put the one with half the splines in the driverside and put the one with the full splines on the passenger side.
Its kind of tricky to get the whole axle into the hole because itll go half way and then want to stop. Theres a lock ring thing on the end which makes it so popping the axle the rest of the way in slightly difficult. I used the good old push and shimmy techniqe. Itll just pop right in.
yea thats the problem im having i changed the lock ring so its tight, the old lock ring was loose, anways ya im 100% sure its in the right way because i just changed the boot but what hes said is right i get it to go in but then it stops as soon as the lock ring is in the there and doesnt "pop" in
Cap'N Chronic
06-29-2011 12:54 PM
HGZ
03-08-2005 01:12 AM
