Help needed: suspension
i am about to get suspension components for my 94 civic si hatch, what do i need to lower it, i want to get adjusttabel coilovers .....but do i need new shocks and struts, just shocks, do i need to get adjustable ones? i know i also pretty much need to get camber correction kits, so dont get tire wear.....but do i need anything eles, whats the minum i need for a good job....
thanks.
thanks.
Down Since Day 1
Good job?
Coilovers or Springs
Decent shocks, adjustable is only your preference
Camber Kit if more than 1.5 (IMHO)
Alignment to adjust toe
Should be all set!
Should be all set!
Re: Help needed: suspension (N21)
adjustable shocks are realy a good thing for ur car if ur into autocross bit also good for street use it would be wise to inviste in some good shocks tokico or tein, zeal, zex, jic or some good brands
Re: Help needed: suspension (spoonspeed)
are adjustable shocks for changing height or is it purly dampening, and such?? so can i get adjustable coilovers and just use regular new shocks....that arent adjustable, even tho i have and will be adjusting the coilovers?
i mean both its better to have adjustables for hight casue the springs are matched with the shocks so its smother ride and dampenig for better stablity in corners ans such
well when u put a set of good shocks on with the coilovers built on then you should use a corner scale to measure the weight of each corner to determin the whay u should make the hight adjustments for front and rear. u want the bac higher then the front just common sense i just used a scale to set mine up maybe you can see about using a scale
thanks for all your help, but i wanted to knwo if i got skunk2 adj. coilovers, or something similar, and then got some tokico regular shocks, what would i have to do after i put them on?..
if i got coilovers and then adjustable shocks, then what would i have to do diff after i put them on, and would i have to change somthing with them, everytime i changeride heirght?
