b16a2 intake no holes for sensors
Location: First in Flight, Type Rs of East Coast, NC, FL
Intake manifold has provisions but no holes for sensor to mount. trying to install on type r head in gsr. What does sensor do?
Re: b16a2 intake no holes for sensors (v-attack)
map sensor is supposed to go there. I put mine in the intake since my intake manifold doesn't a hole either, works just as well. you're ecu will throw a code if a map sensor isnt connected
1 Post
Re: b16a2 intake no holes for sensors (miataguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miataguy »</TD></TR><TR><TD CLASS="quote">map sensor is supposed to go there. I put mine in the intake since my intake manifold doesn't a hole either, works just as well. you're ecu will throw a code if a map sensor isnt connected</TD></TR></TABLE>
It's the air intake temperature sensor, not the map.
okay now i see, so should i just line up the gasket for that sensor on the provision on the manifold mark it and drill it? or....
Re: (v-attack)
You have 3 options.
1. Drill and thread for the OBDI IAT sensor.
2. Install OBDII IAT sensor in intake tube not manifold, extend harness.
3. Get intake manifold from del Sol VTEC (94-95 for sure, not sure about 96-97) or Integra Type R.
HTH!!
Steve
HTH!!
Steve
sohcvtec91hatch
10
12-14-2006 05:48 PM
sporkcrx
17
07-21-2003 08:22 PM
