Loud Blower Motor
Loud Blower Motor
Hey all, I have a 99 civic LX and everytime I have the heat or ac on there are there is a loud noise coming from under the passenger where the floor board.
Can I lubricate a part in it or should I just replace the whole blower motor? It makes a growling noise.
Re: Loud Blower Motor
Take out the blower motor and inspect (3 screws under the blower housing). Often times leaves and other debris get caught on the impeller. The blower motor itself is a PITA to disassemble. it is more likely that you will break something inside before you get to the bearings.
have the same issue with mine. took it apart found leaves and the like in there. cleaned it all up and still makes the same noise just going to call it loose brushes and worn out bearings. headed to the pick apart for a good used one.
It sounds pretty much like this http://www.youtube.com/watch?v=7YimG8ROz1E
Well I took out the blower motor out and turned it on and the fan was quiet... it only makes the noise when the blower motor is installed in the car????
Any suggestions?
Any suggestions?
No debris
Former User
11-28-2012 11:10 AM
