Help w/ b16 parts
Help w/ b16 parts
I been researching for couple hours n didn't find to much
I have a 96 civic dx with a jdm b16a sir2 (the second gen b16) with a chipped p28 ecu
I need to know what parts to get for a tune up...
Spark plugs, cables, distributor and rotor, filters and whatever else
Can somebody tell me what year car I can get stuff from?
And an alternator to
Re: Help w/ b16 parts
Yes you can I have a jdm b16 too.
http://www.hondapartsunlimited.com/p...9/2dr-si/ka5mt <--99 SI
http://www.hondapartsunlimited.com/p...dr-v-tec/ka5mt <--del sol vtec
I'm pretty sure a service manual aint gonna tell to get parts from different cars
get them from 92-95 del sol vtec since it is obd1 like your b16a, You can get from em1 but it is obd2. Most parts are the same but I prefer to order from same obd system.
^^^+1, There are differences between OBD1/2. NP, There is a lot to learn about the b-series family, ask ?'s on HT you'll get a lot of help on here, just make sure you do your research first to further your knowledge.
Ya I see lol... I was told to get obd2 parts like alternator n manifold... But I need a tune up and an alternator... So my best bet would be 92-95 del sol parts For The tune up? Ain't the 90-93 integra the same also?
And about the alternator... I read that the 93 integra one would b the best bet... True?
Ok I see you have an obd1 motor in an obd2 car running an obd1 ecu so you would be running a jumper harness. As for your alt you will need to verify the differences between obd1 and obd2 alts and figure out which one you have in the car then replace accordingly.
and no DA, 90-93 tegs are obd0 so stay away from that stuff..
What distributor are you running? Spark plugs won't change but I'm pretty sure the spark plug wires are different between obd generations.. A good way to verify this wouuld be to pull up www.hondapartsnow.com in two different tabs and in one pull up say a 94 del sol vtec and in the other pull up a 00 civic Si and compare part numbers.
Correct. From a quick search you probably have an obd2 dist. unless you are also running a conversion harness here as well. Usually you run a dist to match your harness, unless of course you run the conv. harness.
NP, I usually do not come in this subforum but I did for some reason last night. I run a b16a in my 92 hatch so I though I would help. I was also planning on running a teg brake setup but have decided to go bigger but still using the teg knuckles and trailing arms.
Oo ok n how's that working out? I heard its not much a difference but it looks alot better. I'm actually goin today to get all the tune up parts hopefully I get the right things... Lol
well my stock brakes are 9.4 n rear drum but I'm goin with itr caliper 11" rotor front and rsx/ep3 10.3" rear setup so it should be a vast improvement.
bhigh
02-04-2009 06:20 PM
