Test for high compression pistions?
I just picked up a car with an LS swap. The previous owner said it was bored with high compression pistons. He didn't build the car himself, so I'm assuming he was told this by the PO before him. So, without pulling the head off to see if they are indeed high compression pistons, is there any way to see if it does have high compression pistons? Would a compression test do the trick? If so, what kind of numbers should I look for?
Btw, I could care less if he lied to me just to sell the car. I would have gotten the car if it still had a D series. I just want to know if I can step down to regular fuel. I will continue to use premium gas until I find out for sure, just to be on the safe side. Not a big deal, I just went from using premium in a car that got 18mpg to this car getting low 30s
Re: Test for high compression pistions?
you cant get a real compression test without the motor not in the car with the starter connected... you can not do a compression test by hand.
And I didn't think a compression test would be able to tell me. Thought I would ask though.
Nextelbuddy
01-09-2004 06:18 PM
